AC brakes
Wkndead
Last Name: Mercier
* REQUIRED* Type and Year of Model Ts owned: 1912 touring, 1922 six post delivery, other
AC brakes
Post by Wkndead » Thu Aug 08, 2024 8:23 am
Are these being made again?
Arbs
Last Name: A
Board Member Since: 2022
Re: AC brakes
Post by Arbs » Thu Aug 08, 2024 5:10 pm
They are being made by Dan Bennett. Contact info here:
Re: AC brakes
Post by Mark Gregush » Thu Aug 08, 2024 5:55 pm
Fantastic! Wonder why there hasn't been more chatter on the boards? Maybe production hasn't ramped up enough to really get the word out yet. Any idea on price?
Arbs
Last Name: A
Re: AC brakes
Post by Arbs » Thu Aug 08, 2024 9:50 pm
I paid $475 for the brakes, AC pedal and longer bolts needed to attach the brakes to the drum.
dr1960
First Name: David
Last Name: Ruedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
Re: AC brakes
Post by dr1960 » Thu Aug 08, 2024 9:51 pm
Dan was at the Chickasha Swap Meet this year and had a good display of the AC brakes. He talked about several improvements he was making to the tooling he got from Larry Sidmore's estate that will improve the consistency of the manufactured product. Very knowledgeable guy and he is doing great work!
David - Yukon, OK
Last Name: Tannehill
Board Member Since: 2002
Re: AC brakes
Post by JTT3 » Thu Aug 08, 2024 10:04 pm
Do AC brakes work in reverse too?
Re: AC brakes
Post by Steve Jelf » Fri Aug 09, 2024 12:24 am
I've read that working in reverse is an advantage they have over Rockies.
tiredfarmer
First Name: leonard
Last Name: simunek
* REQUIRED* Type and Year of Model Ts owned: 1926 touring. 1931 model a pickup, 1947 willys cj2a
Re: AC brakes
Post by tiredfarmer » Fri Aug 09, 2024 7:45 am
They are only made for the small drums, Daniel told me that he can't make them for the large drums because of how the backing plates are bolted on.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: AC brakes
Post by Russ T Fender » Fri Aug 09, 2024 8:22 am
The AC brakes work in reverse but they are not self actuating.
Re: AC brakes
Post by Original Smith » Fri Aug 09, 2024 12:32 pm
The current Rocky Mountain brakes are essentially AC brakes.
First Name: craig
Last Name: leach
Re: AC brakes
Post by Craig Leach » Fri Aug 09, 2024 2:06 pm
I think it has more to do with weight transfer than anything but I feel my A-C brakes work better in reverse than they do foreword. The ancor point is in the middle so half of the shoe self energized foreword & half self energize in reverse.
