Support Forum
Post
by DanTreace » Mon Aug 12, 2024 3:45 pm
Put these 21" 4.50x4.75 Universal tires on the '27 touring in March 2019.
So, 5 years later a bit of tire wear, lots of tour season miles. The worst one on the left is from the right rear, likely from fast acceleration, or perhaps braking hard
The middle is a front tire, and on the right is the spare is as new 2019, hasn't been on the pavement.
Replacing with the same 4-ply, Nylon tires from Universal.
DanTreace on Tue Aug 13, 2024 9:28 am, edited 1 time in total.
CatGuy
- Last Name: Hunt
- * REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post
by CatGuy » Mon Aug 12, 2024 3:52 pm
I wonder what would cause one tire to wear more than the others? I have a Model A that has one worn tire on the right front. Odd.
Post
by DanTreace » Mon Aug 12, 2024 4:24 pm
CatGuy wrote: ↑Mon Aug 12, 2024 3:52 pm
Front tires can wear fast if alignment is off, low pressures, high pressures, or wheel balance if wheel isn't round.
The heavy wear on the one tire, is from rotating, was on the front at first and then a few years ago, was placed on the left rear. That could have hastened my tire wear. Anyway, tires do wear, and better tread is best for safety.
- Last Name: Juhl
Post
by Oldav8tor » Mon Aug 12, 2024 6:20 pm
I have 30 x 3.5 inch Universal Clinchers. The right rear shows the most wear of all the tires and will be replaced shortly. All tires have balance beads in their tubes. I'm going to replace both rears which will leave me with a couple of decent spares after I discard the right tire. The fronts should get a couple thousand more miles before needing replacement. I have a little over 11000 miles on the tires at this point.
Maybe you can see what I'm talking about on this photo. the center tread is almost gone on the right tire.
- 123_1.jpg (55.56 KiB) Viewed 2706 times
Post
by TXGOAT2 » Mon Aug 12, 2024 7:00 pm
I think it is common for the right rear to wear faster due to drive forces. Front tires should wear evenly. My front tires have worn less than the rears, which I attribute to drive and braking forces. Ideal wear is even across the tread, with rears perhaps slightly "flatter" due to less steering forces. Driving fast on the open road will increase rear tire wear, and a lot of city driving might cause more front tire wear than open road driving.
Post
by Allan » Mon Aug 12, 2024 7:37 pm
Might the uneven wear also be contributed to by lax quality control during manufacture. It would be interesting to see how a set of four tyres from the same batch would wear. I can't see modern car tyres wearing this way.
Likewise, my set of 4 Universal T drivers saw one go south long before the others, and that was on two different cars.
CatGuy
- Last Name: Hunt
Post
by CatGuy » Tue Aug 13, 2024 8:26 am
So, does anyone rotate their car tires? Was that a maintenance thing back in the day? Would it make sense these days?
Post
by TXGOAT2 » Tue Aug 13, 2024 9:54 am
Yes. Rotating tires is a time-honored practice and will prolong tire life and improve handling. Ideally, you'd start with 5 matched new tires and put the spare in rotation. A T with Ford wire wheels allows fairly easy tire rotation. A car with two different tire sizes is another matter, and some types of wheels are difficult to deal with.
TFan
- First Name: Jim
- Last Name: Riedy
Post
by TFan » Tue Aug 13, 2024 10:31 am
Found this on the web. Jim
- rotation3 (1).jpg (17.06 KiB) Viewed 2420 times
Art M
- First Name: Art
- Last Name: Mirtes
Post
by Art M » Tue Aug 13, 2024 11:28 am
Tim Juhl,
I have nearly the same experience with my 30 x 3.5 Universal tires as you have. At 11,000 miles the rears are about worn out. However, the left tire has slightly more wear than the right tire. Tires have no balance beads.
The difference in wear might be caused by a slight difference in the hardness of the rubber. I measured the hardness (durameter) of each tire when I mounted them and saw a slight difference. I didn't record the reading. There are other significant causes of wear besides hardness.
I suspect that the front tires will last another 4000 miles. At least I hope so. Tires are a significant expense of driving the car. Not complaining, just stating a fact.
Art Mirtes
hah
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
Post
by hah » Tue Aug 13, 2024 1:08 pm
Must be running circle track. Lop it off like a right rear tire of a race car. lol.
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
Post
by Jack Putnam, in Ohio » Tue Aug 13, 2024 7:47 pm
A slight bend in the front axle yoak will wear one tire, yet the axle will pass the caster/camber test ok.
A hard stop by a curb will do it.
