Roadster upholstery question
fordt
Topic author - Posts: 168
- First Name: Rob
- Last Name: Trippet
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
When finishing out/fastening the seat side panels, do you chamfer down the tack strip to meet the body panel armrest plane? Then slide the extra material over the tack strip and between the metal armrest side?
Re: Roadster upholstery question
Where is the end cap? You failed to mention the year!
Kevin Pharis
- Last Name: Pharis
Looks like 26/27 roadster to me. Wish I could help but never got past the horse blanket phase with that car
- Last Name: Strange
Yes, taper the tack strip, original wood tack strip was also tapered. Used that plastic strip on my '27 touring and did the same like factory, taper the edge down. The Improved open cars didn't use an end cap. Just finish off with Hidem Welt and a end trim nickel fastener.
Then fold under the leading edge of the upholstery about 3/8" to 1/2" to align with the metal edge of the body.
This install was without a top at the time, otherwise the Hidem is over the top cover edge.
Original runabout wood is tapered.
fordt
- First Name: Rob
Sorry about the year omission, but I figured the little metal rolled armrest piece by the door was pretty specific… Thanks for that first picture Dan!
rnkugel
- First Name: Reuben
- Last Name: Kugel
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Rob. Quick question on the material in the pictures on your original post. I need to redo the front bottom on my 15 Touring, and that material is what I'm looking for. What is the material called (I know it is vinyl, but is there a name for the texture) and where did you obtain it? I have looked into a number of the T suppliers and find nothing. Thanks much.
1915 Touring
1926 RAJO Speedster
1926 RAJO Speedster
