Rotary Valve cylinder head identification?
Brian Cress
First Name: BRIAN
Last Name: CRESS
* REQUIRED* Type and Year of Model Ts owned: Speedsters, Roadster, Hack
Post by Brian Cress » Thu Sep 12, 2024 11:34 am
I purchased this Rotary Valve cylinder head at a local auction several years ago. Since that time, I have been unable to locate any information on it. I thought I would share a few photos of it in the hopes that another forum member would recognize it or offer some suggestions on who I might contact for assistance in identifying it. It appears to me that it was originally designed to fit the "490" Chevrolet engine from the 1920's. Any help would be greatly appreciated.
Brian
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Rotary Valve cylinder head identification?
Post by Kevin Pharis » Thu Sep 12, 2024 11:56 am
The basic profile does look a lot like the chebby 4… but looks like it may only use 8 of the head bolts. Could this be an air compressor conversion…? Are there spark plug holes?
Brian Cress
First Name: BRIAN
Last Name: CRESS
Post by Brian Cress » Thu Sep 12, 2024 12:12 pm
Hi Kevin,
Yes, there are spark plug holes visible on the right-hand side of the lower casting which is on the left side of the first photo.
Brian
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Post by Rod » Thu Sep 12, 2024 2:06 pm
I recently watched a documentary on the Rotary Valve head. This link may have some useful info:
http://www.thegreymotor.com/2014/08/dun ... d.html?m=1
Brian Cress
First Name: BRIAN
Last Name: CRESS
Post by Brian Cress » Thu Sep 12, 2024 3:57 pm
Hi Rod,
That is a very interesting link. While I had found information on the Dunston and Coates efforts to create a rotary valve head, the "PatRoVa" and "Bishop" information is new to me.
Thank you for sharing!
Brian
