steering arm
Tom VanMeeteren
Last Name: VanMeeteren
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1923 touring
steering arm
Post by Tom VanMeeteren » Thu Sep 19, 2024 9:12 pm
Looking for a used steering arm for another project. Ball can be worn down a bunch, actually just need the ball its self. Please contact me. Thank you in advance.
Tom
Re: steering arm
Post by Allan » Fri Sep 20, 2024 1:05 am
Tom, if all you need is a ball, the tie rod balls available from the vendors are the same size. I use them to replace the worn balls on early pitman arms.
