rear axle end play
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
rear axle end play
Post by johnr » Tue Oct 22, 2024 4:47 pm
can someone give me dimensions or measurements for maximum movement that is acceptable for rear axle before rebuild.
Thank you.
Re: rear axle end play
Post by speedytinc » Tue Oct 22, 2024 4:56 pm
Axles & carrier must freely rotate. .005" is perfect. .010" is acceptable.
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Oct 22, 2024 10:34 pm
Thrust washers are about 1/4” thick if close to that it’s time to open it up. Ring gear to pinion clearance is.010 +/- .002 so if you have .025 or more then it’s worth a look. Best is to check these when a rebuild is done and write it down for reference in the future.
