Support Forum
ModelTMitch
- First Name: Mitch
- Last Name: Taylor
- * REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
- Location: https://www.fordmodelt.net (Manning Valley, NSW, Australia)
Post
by ModelTMitch » Sat Oct 26, 2024 8:37 am
I decided to give my '24 touring some new carpets, as the first set I made were getting a bit worse for wear! I made the new ones from durable carpet tiles, joined together. I found the carpet tiles to be heavier than normal carpet, and as a result, it doesn't keep skidding around!
Let me know what you think
[/size]
RecklessKelly
- Last Name: Maxson
Post
by RecklessKelly » Sat Oct 26, 2024 9:09 am
Neat concept, but will the adhesive withstand the hot sun?
ModelTMitch
- First Name: Mitch
- Last Name: Taylor
Post
by ModelTMitch » Sat Oct 26, 2024 4:44 pm
The carpet isnt glued to the floor, its just sitting there, it has a sort of non-slip grip surface on the back, which is sitting directly on the original rubber mat underneath.
RecklessKelly
- Last Name: Maxson
Post
by RecklessKelly » Sat Oct 26, 2024 4:59 pm
Ok so you adhered the self stick carpet tiles to a mat of some sort. Curious because I wanted to carpet my car but having it removable with a thin flexible rubber backing I could seal the pedal gaps up a little without interference, for winter cruising.
MariaDenesik
- First Name: Maria
- Last Name: Denesik
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Speedster
Post
by MariaDenesik » Wed Nov 06, 2024 6:20 am
I love the idea, sounds awesome!
