KRW HCCT on eBay
BE_ZERO_BE
Topic author - Posts: 663
- First Name: BOB
- Last Name: CASCISA
KRW HCCT on eBay
FYI : KRW HCCT on eBay
No connection to me.
https://www.ebay.com/itm/126759645129
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Re: KRW HCCT on eBay
Not a bad price for a collector. Is that postage figure legitimate? Seems excessive. I’d invest in one of Kossor’s boxes before I bought an HTTC but that’s just me.
Moxie26
- First Name: Robert
- Last Name: Jablonski
With that coil on the tester, it shows possibility of box contacts needing cleaning ,cushion spring needs tension, adjustment , points need cleaning, and lower vibrator needs tension adjusted. ...... Otherwise, the coil tester is a good working example.
