On the road again
On the road again
Post by Dollisdad » Thu Nov 14, 2024 1:06 pm
Re: On the road again
Post by Dollisdad » Thu Nov 14, 2024 1:07 pm
Post by Dollisdad » Thu Nov 14, 2024 1:09 pm
Post by Dollisdad » Thu Nov 14, 2024 1:10 pm
Last Name: House
Post by George House » Thu Nov 14, 2024 1:37 pm
The homemade “speedster” 8th photo from the top: does he even have a front spring ? And consider the combined effort of redesigning front axle parts necessary for that axle ‘dip’ to accommodate the hand crank. Wow !
Post by Wayne Sheldon » Thu Nov 14, 2024 6:41 pm
George H, Those look like Laurel type "suicide brackets on the front axle. Similar brackets were made and sold by a few companies, however Laurel advertised heavily and is remembered for them. They became known as "suicide" brackets as they held the axle forward ahead of the spring and frame such that IF the bracket or bolts were to break at speed, the chassis would hit the ground and the result could be nasty. The fact is that they rarely ever broke.
One of my speedsters had a similarly "V-ed" front axle to clear the hand crank. It did not have Laurel type brackets, however another major lowering chassis mount that placed the axle very close to the hand crank. I had gotten a front axle that had been "V-ed" by cut and welding. I didn't like the look of the cut and welding on it, so I stuck one end of the axle in an industrial trailer tongue and then jumped up and down onto the other end of it! One of the welds broke, and one cracked slightly. So I ground them out and rewelded them myself. Again stuck one end into the trailer tongue and jumped even more and harder. So after confirming the axle was straight and everything in spec, I installed it and used it. I drove that car hard for several years (even once spinning donuts on asphalt with it just to see if the car could do it!).
RVA23T
Last Name: C
Post by RVA23T » Thu Nov 14, 2024 7:40 pm
Pic# 11, Flooding.
I would be willing to bet the city where the photo was taken, still has a flooding issue at that location!
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Thu Nov 14, 2024 10:50 pm
#6 that driver is very short and possibly a couple of soldiers
