Snowmobile ski question
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Sun Dec 15, 2024 9:39 pm
I am building skis for a snowmobile build and I am wondering do the original skis have a skeg down the middle of the bottom? And can I get width and lengh measurements. Thanks, Dennis
myersair
First Name: Randy
Last Name: Myers
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe and Sedan 1927 four door
Re: Snowmobile ski question
Post by myersair » Mon Dec 16, 2024 11:01 am
Yes they do. I have a set and they are about 3/4 wide.
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Mon Dec 16, 2024 3:05 pm
Randy, Thanks for the answer on the skis, does the skeg run the entire length of the ski? Dennis
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Tue Dec 17, 2024 12:22 am
Here are the skegs on an ARPS Supersnowbird ski.
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Tue Dec 17, 2024 6:24 pm
Thank you Joe for the picture that answers that question. Dennis
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Tue Dec 17, 2024 8:08 pm
Here’s an old post with a drawing with dimensions.
http://www.mtfca.com/discus/messages/59 ... 1480825339
Keep us posted on how your skis turn out.
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Tue Dec 17, 2024 11:58 pm
Thanks for the links, I will let you know what I end up with. Dennis
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Thu Dec 26, 2024 3:36 pm
I finally got my skis finished. They are made out of things out of my raw materials pile (formerly known as a scrap pile) I used wheels that were no good for tires, some broken Model A springs, old bed frames, chain links off a potato digger and what was part of the kitchen remodel at the Elk's Lodge 25 years ago. The skeg on the under side I made 14 inches long and now all I need is snow to test them out. As you can see from the pictures it is not a traditional T snowmobile, my nephew had these tracks for his side by side and doesn't like them so a friend and I put 2 tracks a piece on our T's. We will see how well they work. The only time in my life that I have ever wanted it to snow.
Joe Reid
First Name: Joe
Last Name: Reid
Post by Joe Reid » Fri Dec 27, 2024 12:23 am
Dennis that turned out really nice. Take some shots out in the snow. Model T’s are light but I wonder about boyancy on top of the snow. This is the 30’s version by ARPS.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Fri Dec 27, 2024 9:41 am
Dennis, I'm preparing to make a wood rim for my steeringwheel. I never considered making one like yours. I like it, but I think that I'll stay with the factory shape. :D
Post by RajoRacer » Fri Dec 27, 2024 10:17 am
Rather peculiar use for a rare 1925 steel p/u box.
Post by Mark Gregush » Fri Dec 27, 2024 1:25 pm
or there is this pair with the spindles on Facebook;
https://www.facebook.com/groups/2503824 ... 7365101454
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Dec 27, 2024 1:42 pm
Nowadays, some snowmobile skis have a tungsten carbide rib going down the middle. Expensive, but they don't wear down like regular steel, even the hardened kind.
Joe Reid
First Name: Joe
Last Name: Reid
Post by Joe Reid » Sun Dec 29, 2024 12:24 am
This is how my Supersnowbird started out. The cab metal is pitted more on the inside than outside. The Model A frame was cut, bent and welded to make it straight for some reason and it came with the 25 T pickup box. The frame cross members are now oak and fiberglassed. That is the reason it has the 25T box.
Joe Reid
First Name: Joe
Last Name: Reid
Post by Joe Reid » Sun Dec 29, 2024 12:41 am
Supersnowbird frame. It is bent parallel behind where the cab sits. ?????? You work with what you got.
Joe Reid
First Name: Joe
Last Name: Reid
Post by Joe Reid » Sun Dec 29, 2024 12:53 am
The box required a lot of hammering and reshaping.
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Sun Dec 29, 2024 10:42 am
Joe, You did a really nice job on your Supersnowbird. With it having no rear fenders I thing that the 25 bed looks better than a Model A bed would, looks like a fun vehicle. Do you have to get in and out of the window with that track setup? I am just waiting for snow, all of my snow is coming pre melted.
Post by RajoRacer » Sun Dec 29, 2024 11:50 am
Thanks for the tutorial & explanation, Joe !
Joe Reid
First Name: Joe
Last Name: Reid
Post by Joe Reid » Sun Dec 29, 2024 12:56 pm
The doors are cut and remanufactured to open over the tracks. Still not too easy to get in.
