Weaver tow truck crane
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Jun 06, 2019 12:19 pm
If you have a weaver model t era tow truck crane, I could use a couple of dimensions to help me fix mine up. Tmorsher@icloud.com if you are able to help. Thanks!
Last Name: House
Re: Weaver tow truck crane
Post by George House » Thu Jun 06, 2019 2:17 pm
Tim,
Is yours a 2 Ton or 3 Ton Crane? The former was fitted on Model T s and the latter on TT s...
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Jun 06, 2019 5:54 pm
This is the one I have, George
26modeltt
First Name: Jack
Last Name: Leonhardt
* REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
Post by 26modeltt » Thu Jun 06, 2019 10:00 pm
Tim,
I have a Weaver Model G 3 ton capacity wrecker boom mounted on my '26 TT --- what dimensions are you looking for?
Jack
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jun 07, 2019 12:39 pm
I have Donnie Browns old crane. I could use 1) a couple of photos of this area. 2) dimension of angle iron and aprx length along the edge 3) length of this round rod. 4) a couple of photos and overall length of crank handle so I can carve up a foundry pattern. Post here or email tmorsher@icloud.com mucho gracias!
Last Name: House
Post by George House » Fri Jun 07, 2019 1:13 pm
Tim,
You have a 2 ton crane. Should say so on the cast iron data plate. Yours has 2 axles of mechanical advantage and Jack’s 3 Ton is larger and sports 3 axles. Makes a difference in measurements.
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Jun 20, 2019 10:44 pm
Bump
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Jun 20, 2019 10:46 pm
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri Jun 21, 2019 6:48 am
Is the crank handle 1 in square? is so I know where one is.
