Oil cans...
Daisy Mae
Topic author - Posts: 530
- First Name: Kurt
- Last Name: Andersson
- Board Member Since: 2024
Oil cans...
Wife loves antique shopping, we were at a local place this past weekend and I noticed a shelf of old oil cans (pictured) for sale.. None stamped with Ford, but numerous Eagle brand.
I picked up these three for $20 to have in the shop.
Kind of stirs the imagination as to what else existed in the shop/garage these came from...
George Mills
- Last Name: Mills
Re: Oil cans...
Nice display set !!!!
Re: Oil cans...
Useful, too!
John Codman
- Last Name: Codman
Re: Oil cans...
Those old oil squirters (that's what we called them) are better then the new crappy ones. Nice score!
Mark Nunn
- Last Name: Nunn
Re: Oil cans...
I have a Ford script oil can and it leaks at the bottom seam. Cleaning it well enough to solder it from the inside seems to be impossible.
Re: Oil cans...
I have one like the 3rd down from the top. Been using for years and have to say the old ones are better made than the new ones. Come to think of it, I’ve not seen oil cans in hardware stores. But maybe I haven’t look for any. If I remember I’ll look sometime when we’re in town.
I think the one I have in the picture came from a farm auction years and years ago. My Father would go to them and I came along and helped him bring home all sorts of things we used on the farm.
Daisy Mae
- First Name: Kurt
Re: Oil cans...
John, ya, I liked that one for several reasons...
The long neck...
Bell shape...
And very heavy....no cheap thin metal on this one!!
Every single one of those old cans still had oil... not a leaker in the bunch.
The long neck...
Bell shape...
Re: Oil cans...
When I saw a Ford oil can for $60 at Hershey I skipped it.
Later that day I bought another one for $1.
J1MGOLDEN
- Last Name: Golden
Re: Oil cans...
Steve, would you pay $1.00 (Cash Money) for this one?
Wingnut
- First Name: William
- Last Name: Reep
- * REQUIRED* Type and Year of Model Ts owned: 1924 roadster, 1926touring, 1926 Coupe
Re: Oil cans...
Nice cans Kurt, we too frequent antiques venues, I have an affliction for them , mostly Ford embossed, so far I'm up to at least 20 of the stinkin things. Even some early Noera cans, almost as many generic, you can check 'em out when you come up this spring. Also I've found it's easier to solder from the outside of the bottom of the can if there are holes. Wingnut
NY John T
- Last Name: Killelea
Re: Oil cans...
J B weld on the inside of a Very clean can does the trick
J1MGOLDEN
- Last Name: Golden
Re: Oil cans...
The Eagle oil can factory in West Virginia was closed when the MTFCI 1984 Cross Country Tour from New York City to Seattle, Washington was planned.
The owners opened up by request to make a set of oil cans to give every driver one.
I don't recall the exact number made, but there were several extras.
They looked just like that first photo in this series and had the E stamped in them.
ModelT46
- First Name: Darel
- Last Name: Leipold
Re: Oil cans...
I have about 20 of oil cans marked FORD and they vary . Has anyone posted examples of Ford marked oil cans and who may have made them and when?
Re: Oil cans...
There was a lengthy article in one of the T Club publications some time back - showed the progression & makers, I believe.
John Codman
- Last Name: Codman
Mikey1968
- First Name: Michael
- Last Name: Jewell
Re: Oil cans...
When I had leaking antique kerosene lanterns, I researched how to repair them. Clean the interior up and use POR15 gas tank sealant. Only need about a tablespoon or so of the sealant and slosh around carefully.
Re: Oil cans...
I don't know of any chemical cleaner which will get steel clean enough to be successfully tinned for soldering. Certainly some will do an excellent job in preparation for a POR treatment, which will seal small pinholes at the same time.
Harder to find than the cans themselves are the various mounting brackets to hold them.
Wingnut
- Last Name: Reep
Re: Oil cans...
Collecting Ford oil cans is quite an obsession, as I had stated there are about 20-21 cans in my collection . Of course there are repeats, but I'm still searching for the elusive British can, it has a considerably smaller lid neck. Bit different than our American breed, only saw a picture of one once. Anybody got one? Wingnut
