Top Boot Straps
Topic author - Posts: 3953
Top Boot Straps
What is the proper name for the metal tips that are crimped onto the 5/8" woven cotton top boot straps? I can't find any, because I don't know what they are called.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Re: Top Boot Straps
Too bad RV Anderson isn't around as he could tell you the proper trade name of the end caps.
However, boning end caps are used in corset making and are readily available in 1/2" which may suffice.
For example:
https://www.amazon.com/caps-Spiral-Stee ... 4NSPH?th=1
If you Google boning caps or boning end caps, you can find variations on the steel end caps.
For example:
Re: Top Boot Straps
Is this the type of thing you're looking for? Webbing "C Tips
https://www.ebay.com/itm/126796163293?c ... 10fd5de27b
Or, is this it? Webbing Ball Tip
https://www.ebay.com/itm/Military-Web-S ... 3659070047
Erik Johnson
- First Name: Erik
Re: Top Boot Straps
He's looking for 5/8" C tips like the one shown in the photo below of the original top boot from my father's 1917 touring.
- Last Name: Strange
Re: Top Boot Straps
I did a Google search for "metal belt tips" and came up with a bunch of modern equivalents.
https://www.google.com/search?q=metal+b ... e&ie=UTF-8
Re: Top Boot Straps
If you search for webbing "c" tips you'll find the exact thing, except nobody seems to make them for 5/8" wide webbing any longer. McMaster Carr even carries them, but not for 5/8". Maybe the 1" wide variety can be scrunched down for 5/8"???CudaMan wrote: ↑Sun Feb 16, 2025 8:27 amI did a Google search for "metal belt tips" and came up with a bunch of modern equivalents.
Erik Johnson
- First Name: Erik
Re: Top Boot Straps
As I posted earlier, 1/2" C Tips are readily available from a number of vendors under the moniker of boning caps and are marketed to corset makers. Click on the link in my first post.
In my opinion, using a 1/2" tip on a 5/8" strap would be easier than trying to re-work a 1" tip.
Re: Top Boot Straps
Agreed!! Good find. I missed your earlier posting.Erik Johnson wrote: ↑Sun Feb 16, 2025 12:06 pm
