What Do I Have Here ?
Last Name: House
Post by George House » Mon May 12, 2025 9:42 am
….Can’t call them a “set” because Jno Brown 110 on left has a Steel chimney top. Right lamp is brass chimney top. I’d buy a mate for the steel top lamp. Wonder why Brown offered the steel top ? 1914 TT ? :lol:
Last Name: Hatch
Re: What Do I Have Here ?
Post by Dan Hatch » Mon May 12, 2025 10:23 am
I will take aWAG at it.
Probably a late late 14 lamp or a later teen replacement lamp.
Removed brass for what was happening in Europe after 1914.
Last Name: House
Post by George House » Sat May 17, 2025 6:35 am
Yes. That makes sense Dan. Thanks for the reply. But has any other collectors acquired a 1914 style Jno Brown 110 with steel chimney tops ?
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Sat May 17, 2025 2:35 pm
I have several. Have at least one set with steel tops,.
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Sat May 17, 2025 5:37 pm
which side do you need?
Last Name: House
Post by George House » Thu May 22, 2025 12:17 pm
Howdy Darel,… And thank you for your suggestion. This Jno Brown Model 110 appears to be the right side. It’s original, complete and in excellent condition. Would you or someone else have a comparable left side mate to it for sale ? I’ve never seen steel tops 1914 T cowl lamps on tours….Thank you , gh
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Thu May 22, 2025 12:23 pm
I will ch eck and see if I have an extra left side. It will be a few days before I can check them all./ I have aboiut 20 or more mixed ones. I do know I have at least one set of steel top ones, but have to check to see if there is an extra \left.
Last Name: House
Post by George House » Thu May 22, 2025 12:56 pm
Thank you sir !!
