Assistance Needed - Identify this Key
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Sat Jun 21, 2025 11:27 am
Assistance is needed to document what the key pictured below is used for, when it was introduced and who made it, if it was produced by an outside vendor. Thank you in advance for any information and have a great day.
Re: Assistance Needed - Identify this Key
Post by RajoRacer » Sat Jun 21, 2025 11:43 am
Appears to be a Model A door key.
Cruby
First Name: Carl
Last Name: Ruby
* REQUIRED* Type and Year of Model Ts owned: None
Post by Cruby » Sat Jun 21, 2025 12:56 pm
Not Model A.
Cruby
First Name: Carl
Last Name: Ruby
Post by Cruby » Sat Jun 21, 2025 1:00 pm
Not Model A.
Last Name: Gregush
Post by Mark Gregush » Sat Jun 21, 2025 1:15 pm
Might it go to a padlock?
First Name: john
Last Name: karvaly
Post by speedytinc » Sat Jun 21, 2025 1:41 pm
Looks familiar. I am thinking a spare tire lug lock.
Post by DanTreace » Sat Jun 21, 2025 4:05 pm
Shape of the key seems like 1931A sedan Crown door lock key, but is not that, the key is too stubby.
There are several on the web for sale, all have the "DF" prefix too.
Guess we need an early script Ford key expert ;)
Post by TRDxB2 » Sat Jun 21, 2025 6:23 pm
I also found some others. The number range would indicate the need for a broad variation of different locks. One eBay questioned possible Tractor key but that didn't check out. The keyway looks stamped not cut. The search for an answer continues
df keys.png (361.46 KiB) Viewed 1980 times
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Post by Loftfield » Sun Jun 22, 2025 8:33 am
My recently purchased 1924 Fordor came with an after-market locking steering box at the top of the steering column. I have no idea what the key looks like, but it is just a thought.
Don D
First Name: Don
Last Name: Demio
Post by Don D » Mon Jun 23, 2025 11:24 am
Thanks for all the responses so far. I checked two locking steering columns, not a broad sample, and these keys do not fit. The mystery continues!!
Post by Jerry VanOoteghem » Mon Jun 23, 2025 1:30 pm
I have a key like that too. I seem to recall someone mentioning once that it was for a glovebox on later year Fords. Maybe... maybe not... Web searches don't seem to support this theory. For a tractor maybe?
Post by TRDxB2 » Mon Jun 23, 2025 2:23 pm
With a little help from AI (indicated that "DF" was a YALE series key code). So a search on YALE instead of FORD indicates in this link that it was a Door Key https://www.mtfca.com/discus/messages/8 ... 1256968161
Also there were other key codes for YALE locks used on Ford cars of that era
