axle gear
ryanpad
First Name: Vincent
Last Name: Ryan
* REQUIRED* Type and Year of Model Ts owned: 1913 TOURING CONVERSION
Board Member Since: 2023
axle gear
Post by ryanpad » Wed Jun 18, 2025 4:05 pm
I'm trying to identify the manufacturer of a non ford script gear. It appears to be the same as a ford gear but the axle it came off of was a little shorter and the key slot was different. I'd like to use it but with the proper key.
Re: axle gear
Post by Jerry VanOoteghem » Wed Jun 18, 2025 6:18 pm
I'm always leery about using non-Ford parts. If it were mine, I'd be looking for a Ford gear.
Re: axle gear
Post by RajoRacer » Wed Jun 18, 2025 7:26 pm
I'd have to agree with Jerry unless you want the practice of possibly having to do it over.
