Hi everyone,
I need head bolts to use with my RAJO OHV. Does anyone know what to use? Thanks for your suggestions.
Manny
Rajo head bolts
- First Name: Walt
- Last Name: Berdan
- * REQUIRED* Type and Year of Model Ts owned: '18 Speedster had 25 touring and 26 coupe
Re: Rajo head bolts
For my overhead, I prefer using studs rather than bolts. With studs I can be sure of getting full engagement with the threads in the block. Hopefully that lessens the likelihood of stripping them out. I install the studs with anti-seize to make sure I can get them out again. Not sure the length needed for your RAJO but for my Fronty, I ordered the Model A studs that go through the water outlet area, they are 5 3/4". Snyder's shows them at $2.50 each.
- First Name: Gary
- Last Name: Anderson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster/ Depaul OHV
Re: Rajo head bolts
Hello: I used https://arp-bolts.com/. I used them on my 4 valve Rajo and my 8 valve overhead DePaul. I cleaned each block hole and measured the depth and wrote it down. Measure the thickness of the head gasket and write that down. measure the thickness of the head and write that down too. Call them they may have something close in stock. They have high quality products. Gary
PS: Yes that was a thick head.
Topic author - Posts: 87
- First Name: manny
- Last Name: Kourounis
- * REQUIRED* Type and Year of Model Ts owned: 1915 pickup 1915 Delivery van 1925 Fordor at Lillekers 1924 Tudor
- Board Member Since: 2012
Re: Rajo head bolts
Thanks for the information guys.
Manny
Manny
