Still need some help with length of drag link & tie rod on an early 1910 front axle
Topic author - Posts: 1965
- Last Name: Tannehill
- Board Member Since: 2002
I called myself looking up these measurements but can’t find anything with the exception of a letter of change in 1912. Your help would be greatly appreciated. Best John
frontyboy
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Re: Need some help with length of drag link & tie rod on an early 1910 front axle
I have a brand new adjustable tie rod bought from Lang's for a speedster project that was never used. These are a high quality product and a direct copy of the original.
Not sure if they are available any more. I think they were nearly $200. I would sell this one for $100 plus the freight if that interested.
frontyboy. 2ho6-919*1949
Re: Still need some help with length of drag link & tie rod on an early 1910 front axle
Hey you guys with 1910’s or those that know could you please help me with the length of the tie rod & the length of the drag link. I’m trying to help a friend out that is restoring a 1910 and he needs to confirm the measurements of what he has and what is correct. Thanks in advance, John.
If you need one, you should jump on Frontyboy's offer. The reproductions were of excellent quality, but I believe they are no longer available. 1910 uses the fine thread one.
I bought just the threaded end for my 1912 van from the gent making the repops when I met him at Chickasha in 2010.
Howard sent you an email. Best John
