Front End Lubrication
Post by Original Smith » Sun Jun 29, 2025 5:20 pm
When I rebuild my front ends, I pack the pitman arm ball, and the tie rod ball with old fashioned fiberous wheel bearing grease, but what about the future lubrication? If you wish to remove the ball caps and repack them, good for you. I'm a little bit on the lazy side, so this is what I do. While oiling the oil cups I squirt some oil into the pitman ball area, and the draglink ball too and rock them back and forth. Works for me.
Re: Front End Lubrication
Post by Jerry VanOoteghem » Sun Jun 29, 2025 5:54 pm
Works for me too!
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Sun Jun 29, 2025 6:48 pm
I do the same. And I use chainsaw bar and chain lube. The heavy summer blend.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Jun 30, 2025 2:44 am
Bar oil is a good idea. I have good luck with gear oil & if you change the rear end as often as we should save it for that reason, then it's free
& save the bar oil for the chain saw.
Post by Original Smith » Mon Jun 30, 2025 12:43 pm
I failed to mention, I do the same for the wishbone. Sorry I failed to mention that.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Mon Jun 30, 2025 4:11 pm
The 600wt oil works well for this. Stays put. I use it on gears on my old Craftman lathe. Doesn't fling off.
