What is the inside diameter for upper and lower radiator hoses for a 26 ?
Was the I D the same for all years?
Radiator hose ID
Dennis_Brown
Topic author - Posts: 269
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Re: Radiator hose ID
2" for the outlet - 1 & 3/4" for inlet.
Rajo gave the diameters. But there is a different in length. Vendors sell the upper hose, 4", to fit '26-'27 but may need to be trimmed a bit for earlier models. Water Outlet to radiator neck dependent.Dennis_Brown wrote: ↑Sun Jul 20, 2025 9:25 pmWhat is the inside diameter for upper and lower radiator hoses for a 26 ?
Model T
Early models (17-19) 3-1/4" long hose
Later models (19-27) had a 3-1/2" or 4" long hose,
Model A 1928-29
Short lower hoses are 1-3/4" I.D. x 3-1/2" long
Upper hose is 2" I.D. x 7-1/4" long.
All years '17-'27
#3006 Cyl head inlet hose (upper) 2" Dia. x 4" L. (Brass radiator, '09-'16 2" Dia. x 3 1/4" L)
#3944 Outlet hose(s) (lower) 1 3/4" Dia. x 2 3/4" L
