Float a Ford Auxilliary Brakes
Manitouc
First Name: Grant
Last Name: Jones
* REQUIRED* Type and Year of Model Ts owned: 1923 Model T Touring
Post by Manitouc » Tue Jul 22, 2025 11:44 am
I have Float A Ford auxilliary shocks on my 1923 Toring with small drum axles and Ruckstell.
I would like to keep the shocks but install some form of auxilliary brakes. Rocky Mountains will not work.
Like to know if anyone else has done this.
First Name: craig
Last Name: leach
Re: Float a Ford Auxilliary Brakes
Post by Craig Leach » Wed Jul 23, 2025 2:18 pm
Hi Grant,
Judging from the pics I found of Float-A-Ford's A-C, Stronghold & APCO small drum Auxiliary brakes should fit you may need to remove a little
from the underside where it can't be seen for clearance. The A-Cs I believe are available.
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Wed Jul 23, 2025 9:17 pm
Hi Grant,
The AC Brakes are available from Bennet Machine in Oklahoma. I got a set from Daniel, great guy to deal with.
