Well, you get your self a "Dyerman" Model T Ford Generator Test Bench out of it all
My buddy and I completed this wonderful test bench using the above bits and bobs and are on to revision 2 as seen following. So far we have fixed and tuned 4 generators with at least 1 more to go on the 'repair list'.
It does 6v and 12v testing. To do add is a fitting to clip the lead wires onto when not in use (as well as a general tidy up of the leads).
It has been a lot of fun:
(to adjust the ampmeter to read 'zero' - just turn the big slotted 'button' on the face)
(to adjust the tension on the vee-belt, slacken the front bolts a little, move the mounting and re-tighten the bolts - easy peasy)
