We just noticed blackened paint by the rear brake . .
Lakesailor
Topic author - Posts: 7
- Last Name: Markel
- * REQUIRED* Type and Year of Model Ts owned: 1909 Toring
and are wondering if it’s a lack of grease, or something worse . . Any thoughts ?
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Re: We just noticed blackened paint by the rear brake . .
Your brake shoes are dragging on the drums and the heat from the friction burned the paint.
yup
kmatt
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
James, Fix and adjust the dragging parking brakes not to drag on drums when hand lever is forward. Also read post on how to adjust for a free neutral. When you clean and repaint the drums in the damaged area, keep the repaint to a thin layer, the burnt paint looks way to hick in the picture.
Lakesailor
- Last Name: Markel
