Restore It? -> N.A. Petry Co Inc - Exhaust dump
fireheadman
Topic author - Posts: 146
- First Name: Ben
- Last Name: Piraro
- * REQUIRED* Type and Year of Model Ts owned: 1911 Model-T Pie Wagon
Is this worth trying to restore?.... or has anyone come across them somewhere to get replacement parts?
This came off my Pie Wagon and does work, but it needs some attention to make it work correctly
Member: Mile High Pedal Pushers - Denver, Colorado Chapter
https://www.youtube.com/watch?v=e5FPWnxG_9w
fireheadman
- First Name: Ben
- Last Name: Piraro
Re: N.A. Petry Co Inc - Exhaust dump
or maybe there is another manufacturer/type in its place to use.... if you wanted to put something like this one your exhaust?
I've also see this setup with a whistler --> https://forums.aaca.org/topic/337995-pe ... ut-wanted/
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Re: Restore It? -> N.A. Petry Co Inc - Exhaust dump
There were Cooper cut outs reproduced at one point.
I'll see if I still have one.
Ed Fuller
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
I have one exactly like that on my speedster. Works great!
That one, my friend has seen better days - wall hanger, perhaps ?
I can understand such an item being part of an exhaust whistle, but what use is it just to divert the exhaust straight out?
Ed Fuller
- First Name: Ed
- Last Name: Fuller
What use it to divert the exhaust straight out?
Because it just sounds plain cool!
fireheadman
- First Name: Ben
- Last Name: Piraro
I believe its purpose was to offer a hot rodding experience from the massive 20 hp engine we have…. And now that I know it was on there. I can only imagine the thoughts my grandfather had using it.
I’d like to put one back on it, but this one seems destined for the wall decor
