Exhaust wrap and a heat shield. Helps a lot.
Just did a maintenance check this morning. Almost no lint in the transmission screen and bands have seated nice with no further adjustments needed. Greased and oiled everything. All set for a nice ride.
Got cab heat control
Mountainrider
Topic author - Posts: 178
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Duey_C
- First Name: Duane
- Last Name: Cooley
Re: Got cab heat control
I like that Neil! Simple and interesting.
Like it. I use exhaust wrap on my T-uner. I can drive around at Interstate speeds for an hour, stop and touch the wrap without fear of leaving my skin on the manifold. There is an advantage of increased engine efficiency in using it too. You get more horsepower (>.1hp) because the wrap will keep exhaust heat in the exhaust manifold or exhaust pipe instead of dissipating to other areas. When heat is contained within the exhaust system it will improve the flow of exhaust gasses throughout the entire system. Looks cool too.
