Throttle linkage rod is too short.
LittleTimmy52
Topic author - Posts: 137
- First Name: Lucas
- Last Name: Milatti
- * REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
- Board Member Since: 2025
I have a 1917 touring, but instead of the l2 I have the l4 Kingston carb, I've always noticed that the butterfly valve on the carb doesn't close all the way cause the linkage is a tad short and or the connection on the valve is bent looking. What length of rod should I get to replace it? And is this part bent, it seems to me like it is.
Re: Throttle linkage rod is too short.
Yes, the carb. throttle lever has been bent. Post a photo of the other end.
