26/27 enclosed car gas tank
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Post by Will » Mon Sep 15, 2025 1:42 pm
Im helping a friend remove a gas tank form a 27 enclosed car, What steps do I need to do to remove it?
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
John Codman
Last Name: Codman
Re: 26/27 enclosed car gas tank
Post by John Codman » Mon Sep 15, 2025 2:23 pm
I think that the procedure varies with body style. I have heard from several '26-7 Model T' owners that you can carefully wiggle the tank out of the car without removing the steering column. On my '27 Touring car the column has to come out. Before anyone hops on to this, if my tank ever has to be removed again, I'll pay $50 to anyone who can remove it (I'll unbolt and unscrew whatever needs to be) without removing or at least lowering the column before you to remove the tank.
Post by DanTreace » Mon Sep 15, 2025 4:04 pm
This older post has some real good tips. Two person job as the cowl sediment bulb fitting to the tank has to wrangle in and back out when replacing. One can do it, but helpers are nice to have. ;) Done it solo many times in open cars, the dash sometimes needs a pull just below the switch opening as the flange on the dash panel can interfere.
https://www.mtfca.com/discus/messages/5 ... 1429830438
Service Bulletin gives step by step on removing and installing.
Safety first, drain tank, remove battery cable so no elec. is there, and remove dash switch as the thick loom is a handicap.
Will
First Name: Will
Last Name: Copeland
Post by Will » Mon Sep 15, 2025 7:41 pm
Thanks everyone, He was able to get it out. Now I get to clean it!
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Mon Sep 15, 2025 8:20 pm
Well I finally bit the bullet on mine back last winter and it cost me 275 to get mine vatted and lined at a radiator shop in Concord Nc. Websters radiator i think it is.
I hope it works out.I just did not think i could get it clean enough with the baffles in it. i soldered a copper patch over 2 rust holes and already had in the electrolysis tank for a couple weeks so it was clean persay, but not to suit me. That is the last think I want to have happen if i ever get to tour with the club with my finished project, have a fuel system clog! Yuks.
