Magneto Field Coil
Topic author - Posts: 106
- First Name: Bill
- Last Name: Austen
Magneto Field Coil
Who rebuilds the Model T Magneto Field Coils? I have 3 early field coils that have been checked cleaned and coated that I plan to sell in the near future.I need to have a double stack 1915 coil rebuilt, but can't remember who does the rebuilding. Thanks MTFCA
W. Austen
W. Austen
- First Name: Ted
- Last Name: Dumas
- * REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Re: Magneto Field Coil
Total Recoil. Google for contact info.
Wally Szumowsky sold Total Recoil and retired, and the new owner has since died. Has anybody else taken it over? If not, you may need to turn to Birdhaven, Bob's, Chaffin's, Lang's, etc. (Google Total Recoil and you get video games.)
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
If anyone knows how to contact Wally S I'm sure he would know. If you have a lot of time you can do it yourself. I did.
- First Name: BOB
- Last Name: CASCISA
R.V. Anderson rewinds Mag coils.
Hers is a link to his profile.
memberlist.php?mode=viewprofile&u=795
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Another good source:
If the 3 have only been cleaned and checked, at this point, unless they have been completely rebuilt they are still cores. Any coating you put on isn't going to stick for very long to old oily surfaces and the old probably rotted wrappings. If the the insulator between the winding's is still good, you might get by with un-soldering the connections between the coils, re-wrapping the coils, sand blasting the frame, reassembling, coat and bake.
- First Name: R.V.
- Last Name: Anderson
First, what Mark said.
Next, I do rewind field coils; have done many thousands using all new copper, insulators, contact blocks, etc. Everything is new but the frame itself. Surface grinding available. All units carry a lifetime warranty.
rvmodeltATnetsyncDOTnet
- Last Name: Blaydon
Do yourself a favor get the pole faces and the ring to block surface ground so that they are flat and parallel. It will make getting the proper air gap easy.
- First Name: Bill
- Last Name: Austen
This is a great help-
https://www.youtube.com/watch?v=VTNQiabdZp4
