Bob Bergstat
WorldChamp1914
Topic author - Posts: 403
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Bob Bergstat
Hi everyone, Is he still on the forum?…….I am missing the ultra thin hexnut on my steering wheel tilt accessory….Thanks
- Last Name: Hjortnaes
Re: Bob Bergstat
I think he is still here, but he sold everything.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Thanks, I found him on EBay….Thanks
Re: Bob Bergstat
I'm in need of the lock nut also.WorldChamp1914 wrote: ↑Tue Oct 28, 2025 7:34 pmHi everyone, Is he still on the forum?…….I am missing the ultra thin hexnut on my steering wheel tilt accessory….Thanks
The nut needed is a lock nut & is the same thread for all of the steering wheel nuts 5/8" x 16 thread (not a standard size). It may be the same size as the Drive Shaft Castle nut. I'm going to check that out. If not grind down a steering wheel nut
Re: Bob Bergstat
Do you have a link to the nut on eBay? I need one also
- First Name: Austin
- Last Name: Farmer
Re: Bob Bergstat
For what it's worth, he is Modelt2001 on ebay.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
5/8 -18 doesn’t work…..I bought some on EBay……the 16 isn’t available there
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Search is hex panel nut
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Now that I know the correct name….I still can’t find 5/8-16….panel hex nut….Grainger doesn’t have any.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Bob Bergstat
Have you tried McMaster-Carr Industrial supply in Atlanta? Opps. Just looked. They don't have them, either.WorldChamp1914 wrote: ↑Wed Oct 29, 2025 2:50 amNow that I know the correct name….I still can’t find 5/8-16….panel hex nut….Grainger doesn’t have any.
- Last Name: Hatch
Re: Bob Bergstat
Maybe this helps
https://www.partswarehouse.com/Homelite ... 011710.htm
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Thank you.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Thanks for the link, but it is 1/2 inch thick……I did hear back from Bob on EBAY….everything was sold to BirdHaven
Re: Bob Bergstat
That's a very odd thread. You are lucky to find anything usable even with modification needed.WorldChamp1914 wrote: ↑Wed Oct 29, 2025 4:24 pmThanks for the link, but it is 1/2 inch thick……I did hear back from Bob on EBAY….everything was sold to BirdHaven
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
I just talked to Steve Lang, he recommended cutting down a steering wheel nut because it’s 5/8 -16….so I ordered a steel one
Re: Bob Bergstat
If you got the correct part please let me know where you got itWorldChamp1914 wrote: ↑Thu Oct 30, 2025 3:02 pmI just talked to Steve Lang, he recommended cutting down a steering wheel nut because it’s 5/8 -16….so I ordered a steel one
I ordered 2 from the link above https://www.partswarehouse.com/Homelite ... 011710.htm
Here is the outcome
Re: Bob Bergstat
I remember a time on the Forum where nearly any member here could whip these out on their lathe.
I'm dating myself, I suppose - Times change.
Re: Bob Bergstat
That's sure as s_ _t what I would do !
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
I bought some steering wheel caps from Langs….must be machined……the one from the Homelite website is 1/2 inch thick
- Last Name: Hatch
Re: Bob Bergstat
Sorry for the link. Guess you can’t trust the internet.
Re: Bob Bergstat
No problem with the link only the people responsible for service at the Parts Warehouse. The issue was simple "the nuts shipped didn't match the part number on the pouch which is what I ordered, why?". The progressive series of questions appear for me, not them, to verify their catalogue pages. Don't understand why they couldn't ask for all that info in the first pass, but they were still unnecessary. They never indicated if the mistake was in picking the wrong part or in labeling what they have. I actually ordered from them in the past without any issue.
