Rebabbit Block
Danny Carstensen
Topic author - Posts: 29
- First Name: Danny
- Last Name: Carstensen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1922 Roadster
- Board Member Since: 2014
Rebabbit Block
Looking to have my block babbit redone. My 22 has .016 end play & no shims left on the rods.Thinking of grinding the crank .010 under , pickup rods from a supplier. The block is std bore with no ring groove. Hone and ring the pistons. Not to many left doing the babbit thing.Can't seem to contact Andy Loso. Who else does babbit within a reasonable distance?
Dan (Southwest Minnesota)
Re: Rebabbit Block
Model T engine bores don't get a ring groove as the top compression rings goes to the top of the bore.
Joe Bell, Kevin Prus or Jack Putnam are close.
Danny Carstensen
- First Name: Danny
Re: Rebabbit Block
Thanks Steve. Where are these men located?
Re: Rebabbit Block
I believe in Ohio.
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
Re: Rebabbit Block
I would be happy to Babbitt your block, I've 30 years experience, did the T-100 project for Ford Motor Company, work for the Henry Ford Museum and a few hundred other T engines using KRW equipment. I only do Model T engines, none other. I'm located in NW Ohio!
- Attachments
- photos b4xp 048.jpg (25.76 KiB) Viewed 5729 times
- photos b4xp 539.jpg (38.13 KiB) Viewed 5729 times
Sean Butler
- First Name: Sean
- Last Name: Butler
Re: Rebabbit Block
Lookin' good, Jack! Do you bore your own rods as well and if so, what sort of setup do you have?
Sean Butler
Huntington Beach, CA
Danny Carstensen
- First Name: Danny
Re: Rebabbit Block
Thanks for all the information. Andy just called me, he's been pretty busy. Thanks again
- First Name: Jack
- Last Name: Putnam
Re: Rebabbit Block
Sean: Yes I bore my own rods. They are set up on a milling machine, then bored to desired size.
Sean Butler
- First Name: Sean
- Last Name: Butler
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: Rebabbit Block
I deliver to hershey every year to East coast buys, Joe
