Helping a Friend with a Promise
Topic author - Posts: 5531
- First Name: Henry
- Last Name: Lee
From years back.., keeping my word to assist in the parts that do not exist. Installing a Vega Steering Box, High angle wedge for the column drop, and custom billet aluminum windshield stanchions. Posting this to show others how to do it. The key in making these, you must use a variable speed metal capable band saw at half speed, canning wax as a lubricant, and patience.
Please Note: Not interested in doing more...., I am just keeping my word.
- First Name: Henry
- Last Name: Lee
Re: Helping a Friend with a Promise
It will have wing wings as well.
Will provide more as this project progresses.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Nice work. Are they going to be polished when completed?
- First Name: Henry
- Last Name: Lee
To a mirror finish!
frontyboy
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
That is one of the most informative posts here and a long time not only did you show how but you included how and what you used to compete the project. I wonder where you found that cowl piece, did you make it or find a vendor. I have the same wood firewall and would like to add a form bent cowl as shown.
thank you for the post,
frontyboy
frontyboy
- First Name: Henry
- Last Name: Lee
Well finally finished up the truing of the billet on a vertical belt sander using 40 grit. I drill completely thru the stanchions and then TIG up the holes for a full depth thread.., old school. Now making windshield/wind-wing templets and setting the style as we agree on the final design. Next will post pictures on how to carve the billet the easy way.
Stay tuned for more magic.
- First Name: Henry
- Last Name: Lee
Some added items......,
Firewall dishing for an overhead conversion! Lower floor board heat shields are a must!
- First Name: Henry
- Last Name: Lee
Bucket seats are nice but they do not meet the stature requirements for modern old aged folks...., converting to a love seat design!
Art Ebeling
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
That is very nice and creative work. Art
Mark Chaffin
- Last Name: Chaffin
The Michelangelo of Model T art.
varmint
- First Name: Vernon
- Last Name: Worley
Curiosity...
Is the aluminum piece on the cowl, tube or solid?
For the heat shields, did you use a bead roller or a press?
Is the seat center vertical piece aluminum or steel?
Vern (Vieux Carre)
- First Name: Henry
- Last Name: Lee
Billet T6061 aluminum (solid).
Galvanized sheetmetal formed on a box brake with 4,000 degree proof rock wool behind it.
Seat was supplied by customer (steel) just modifying for comfort.
- Last Name: Hatch
Very well done Hank.
Reminds of some Herm’s post on engine work.
This what this Forum should be about. Learning how things are done.
Again, well done. Please continue doing this. Dan
- First Name: Henry
- Last Name: Lee
The key in a good job is quality material, T6061 billet, good files and rasp. When ever you are working any soft material use canners wax by means of rubbing your file. They never plug and clean up easy. Watch your pressure when cutting on the strokes. I use lay out dye for a good contrast.
- First Name: Henry
- Last Name: Lee
I have been using the same files for over 12 years. After 2 cups of coffee this morning.., one is in the rough.
- First Name: Henry
- Last Name: Lee
Well both frames are in shape today. Did some shopping for peep mirror mounts and they all look like flimsy crap...., Soooo I started making dagger style.
- First Name: Henry
- Last Name: Lee
So after all the rough in with a rasp file, I come back with a conventional double bastard and then down to a single bastard file. Then I start with 80 grit, 120 grit, 240 grit, 320 grit all dry. As you can see depending on the cloth wheel weave and jewelers rouge used will determine your sheen. We are going for a German Nickel appearance. Pretty close!
- First Name: Henry
- Last Name: Lee
All what is left for the windshield is upper and lower channels with retainers/cut and polish the glass. Started the pull back pleated seat wrap for back and cushions.
- First Name: Henry
- Last Name: Lee
Mark Chaffin
Absolutely amazing craftsmanship my friend!
