Is there a dark mode setting for the forum
WorldChamp1914
Topic author - Posts: 375
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Thanks, Gary
- First Name: Austin
- Last Name: Farmer
Re: Is there a dark mode setting for the forum
I do not believe so. The only adjustement I know of is the screen of whatever device you use, which has nothing to do with the forum.
I don't intend to express any knowledge about the forum software (I'm just an old IT guy), just did a Google search.
There is an "extension" that can be added to the Forum software (phpBB) https://www.phpbb.com/community/viewtopic.php?t=2557121
However adding extensions add to the complexity of maintaining the Forum as a whole & compatibility testing of any new extension with the current configuration would be required. Another method would be to add a dark theme (how pages look) but that's extra work & testing as well
It would be up to the Forum Administrators to decide if they could handle it with their current workload.
Also with any extension they always add....
Except where otherwise noted, the phpBB Team is not responsible nor required to provide support for this extension. By installing this extension, you acknowledge that the phpBB Support Team or phpBB Extension Customisations Team may not be able to provide support.
WTF is a "dark setting" ?????
Moxie26
- First Name: Robert
- Last Name: Jablonski
Your phone is adjustable, just go to settings and put in your preference.
