Hi all,
I am looking for clear photos how the 1910-1913 rear frame to body brackets were attached to the frame and how this frame was build up at the rear.
Andre
Belgium
1910-1913 rear frame to body brackets.
AndreFordT
Topic author - Posts: 564
- First Name: Andre
- Last Name: Valkenaers
Tbird
- First Name: Mike
- Last Name: Bird
Re: 1910-1913 rear frame to body brackets.
Andre,
There are a couple differences, between the 10-13 rear body brackets. The 1909-10 had the rear fender irons also attached to the rear body brackets they are called butterfly brackets. The 11-13 eliminated the need of the rear body brackets with the rear fender irons. The brackets are held on with three bolts two on the top and one on the side. The frames are different as well between a early frame 09-13 and a later frame after 13. These photos are of a 1911-12 frame.
- First Name: Tom
- Last Name: Rootlieb
Here you go.
AndreFordT
- First Name: Andre
Thanks all.
Now I know the way to go.
Andre
Belgium
Andre
Belgium
