Top/Lid for Boyco Running Board Cans
DontKnowMuch
Topic author - Posts: 209
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
I am looking for some tops/lids for Boyco gas/oil/water running board cans. I tried to find the chafing dish fuel cans as suggested in the past but they are not the right size on the brand I found.
I talked to Howell's Sheet Metal who makes new cans and holders but they have not found a source for the lids.
Any suggestions?
Any suggestions?
Re: Top/Lid for Boyco Running Board Cans
I asked about this a few years ago and got several suggestions. None of them turned out to fit. One of my cans was leaking around the spout, so I emptied it, put water in it and tried to solder the leak. It turned out that the spout was aluminum and melted! I thought I would solder on a steel spout from some other can (lacquer thinner, paint remover, etc.), but so far all I've found have been too large or too small. For now I'm plugging the hole with a cork. (A rubber stopper didn't survive.)
A company has tooled up and makes reproduction caps, but real pricey for a set of 3
https://www.ebay.com/itm/BOYCO-Emblem-L ... SwDN1UQuuu
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
I seem to remember Sterno /Chafer lids being the correct size?
Last edited by ThreePedalTapDancer on Tue Mar 17, 2020 5:47 pm, edited 3 times in total.
Adam
- First Name: Adam
- Last Name: Doleshal
And those reproduction lids look terrible compared to an original! They are a regular modern style screw cap with the logo stamped on them. Not at all what I’ve seen on originals.
Sterno now comes in a can with a press-in lid, but that Chafer looks like it might work.
- First Name: Henry
- Last Name: Lee
The lid and top from an Oatley PVC primer can is very close.
Hope this Helps,
Hank
Hope this Helps,
Hank
I took a Boyco lid when I went to town today, so I could compare lids on various products. Oatey PVC stuff is a no-go. Their lids are all too big or too small. The same goes for all the thinners and paint removers I saw. At the hardware store, the only place in town that I know of with chafing fuel, all the cans have press-in lids. All the B&S gas tank lids I have tried were also wrong.
I wonder where this guy is getting the lids he stamps with the Boyco name. They are obviously not a reproduction of the original Boyco lid.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
What a Deal... Only 65 bucks each! They should seal leak free for that amount!
1912 Torpedo Roadster
Adam
- First Name: Adam
I’ve seen good selections of new lids of different sizes in Amish dry goods stores.
Seems new caps then weren’t too cheap either!
.15 cents in 1922 is $2.55 today
I thought I would look for a source with a Google search of steel can manufacturers. I am always amazed by how many big companies have websites that range from user-unfriendly to downright dysfunctional. I submitted inquiries where I could. I'll report if there are any responses.
ModelTWoods
- First Name: Terry
- Last Name: Woods
If you read the entire description on the Ebay ad that is posted, you'll see that a company is not presently making them, but the set of three is for sale by an individual who states the name of the company who did make them. Originals were straight and sharp at the bottom edge. My originals don't have a rolled edge at the bottom. BTW, I may have a extra lid or two, but they are likely bent or dented. If they had been choice grade, I wouldn't have discarded them. Also, I am 200 miles away from my parts and with this virus going on; don't email me about a dented lid unless you have plenty of months to wait for a answer.
Orignal BOYCO lid. 1.5" x .5".
Dropacent
- Last Name: Morsher
There are a lot of versions of boyco can lids. Lots of variables
WayneJ
- Last Name: Jorgensen
I was at a Dollar Tree store last week and they had charging dish fuel in a screw top can. No idea if it will fit, but it was a Dollar.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
Novice
- First Name: Jim
- Last Name: Davis
3D Parts Printer
You may be able to have the lid reproduced including the logo with a 3D printer.
JBog
- First Name: Jason
- Last Name: Bogstie
Re: 3D Parts Printer
Old post, I know. I read this last night and it got my mind going!
It took Steve’s photo of the dimensions and I played around with the TPI and I managed to 3D print a cap that fits! It’s just a rough attempt to get an idea. The cap appears to be 5 TPI.
I understand the color and look isn’t right, it’s what I had in my printer when I got this wild hair last night.
Jason
do an internet search, and you'll find what thread count is depending on jar lid diameter: Knuckle Thread DIN 168
or, search for anything to do with "400" type threads relating to bottles or cans.
the reproduction lid shown on the eBay ad is nothing more than a standard glass-jar lid with "BOYCO" stamped into it.
- First Name: Henry
- Last Name: Lee
Would be pretty simple to make a mold using your can's male threads and cast them out of brass or aluminum. Youtube has great simple videos. Don't over think it thinking you are going to find something modern that is going to fit a non standard thread, this was way before SAE standards.
If you have lathe access you can make lids from billet material.
I made a set for a different brand from brass. Knurled the outside.
You gotta make a cutter that profiles the very round thread.
