Safe cranking technique
Rich P. Bingham
Topic author - Posts: 1776
- First Name: Rich
- Last Name: Bingham
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Re: Safe cranking technique
Here are 2 video examples from fellow poster Steve Jelf of how to crank a Model T
https://www.youtube.com/watch?v=3pv6HWWOGYA
https://www.youtube.com/watch?v=B_lkFGQToIw
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
For Petes sake its a joke.
NoelChico
- First Name: Noel
- Last Name: Chicoine
- * REQUIRED* Type and Year of Model Ts owned: 1920 roadster, 1923 Touring, 1926 Coupe
REALLY high compression head??
- Last Name: Hjortnaes
Gonna split his pants and then what?
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
I’ve seen worse attempts.
Mike Silbert
- First Name: Mike
Video #2 I sent is a demonstration of a worse attempt.
Or how you can hurt yourself doing it wrong.
Those guys look like they are working really hard trying to hurt themselves.
I don't know if Steve made it as a warning or as a joke.
I take it as both plus a reminder of the danger when things are wrong.
Maybe he will answer with the background of the video.
Mike
Mike
dykker5502
- First Name: Michael
- Last Name: Deichmann
#1 is made to show how easy a model T is started by hand crank when it is in proper state.
No need to wind the handle likecrazy.
Ford Model T 1914 Touring
After performing proper starting preparations, one should "lift" the crank with moderate vigor. Good maintenance and correct technique will assure success while avoiding broken bones, damaged teeth, and split britches. If it is found that the engine needs to be "spun" in order to clear a flooding condition, turn the ignition off first.
#2 demonstrates that with correct pulling, a kickback is harmless. I broke a wrist by cranking a tractor the stupid way, and that was a serious reminder that correct cranking matters.
