My '26 speedster came with a low head. I have a high head in my stash. It looks like the high head has larger water jackets (better cooling?). What would your suggestions be on which would be best and why?
Thanks!
Low vs. High Head
Petrah Phyre
Topic author - Posts: 166
- First Name: Sean
- Last Name: Pownall
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Re: Low vs. High Head
Open your wallet for a new Prus head.
To answer your question, it kind of depends on what radiator you're using. The low head water outlet lines up well with a brass radiator and high head lines up better with a later, high radiator, (all assuming you're also using the correct water outlet for each). Since you have a speedster, any combination could be possible. I would tend to use the head that fits up well with whatever radiator you have.Petrah Phyre wrote: ↑Fri Feb 06, 2026 6:36 pmMy '26 speedster came with a low head. I have a high head in my stash. It looks like the high head has larger water jackets (better cooling?). What would your suggestions be on which would be best and why?
Thanks!
ModelTWoods
- First Name: Terry
- Last Name: Woods
The high head does have a larger water capacity, but the low head has a slightly high compression ratio (i.e. smaller combustion chamber).
Petrah Phyre
- First Name: Sean
This is what I saw listed on TBay. Didn't know if it was true or not. May be why the guy who originally put it together used the low head. Is this why the 22hp vs. 20hp? The low head is already painted, so I might just use it. In South Dakota, so it doesn't usually get too warm. If I find I need the extra cooling, it's not too hard to change out. Not like I'm going to win any competitions for 'ALL ORIGINAL' with a speedster anyway.ModelTWoods wrote: ↑Sat Feb 07, 2026 8:22 pmThe high head does have a larger water capacity, but the low head has a slightly high compression ratio (i.e. smaller combustion chamber).
ModelTWoods
- First Name: Terry
- Last Name: Woods
The horsepower difference may have had something to do with the head change, but also with a cam profile change, which I have read, also occurred during Model T production. If you really want to go, Zoom Zoom with your speedster, and the engine is presently, basically stock and your on a budget, Buy a reground, or better yet, a new .280 lift cam, better carburation (like a Stromberg OF or similar), or change to a Model A intake, exhaust and carburetor.Petrah Phyre wrote: ↑Sat Feb 07, 2026 10:11 pmThis is what I saw listed on TBay. Didn't know if it was true or not. May be why the guy who originally put it together used the low head. Is this why the 22hp vs. 20hp? The low head is already painted, so I might just use it. In South Dakota, so it doesn't usually get too warm. If I find I need the extra cooling, it's not too hard to change out. Not like I'm going to win any competitions for 'ALL ORIGINAL' with a speedster anyway.ModelTWoods wrote: ↑Sat Feb 07, 2026 8:22 pmThe high head does have a larger water capacity, but the low head has a slightly high compression ratio (i.e. smaller combustion chamber).![]()
