Support Forum
- First Name: Austin
- Last Name: Farmer
Post
by 1925 Touring » Thu Jul 10, 2025 1:46 pm
It's always fun, to me, when working on the T, to look for where there is 'Ford' stamped into each and every part. I thought this would be a fun thread to have, posting pictures of all the 'ford's on our Fords.
Here's one, on a rear axle shaft.
Where's the ford on your car?
Post
by speedytinc » Thu Jul 10, 2025 1:59 pm
Thats a fine idea.
However, in a semi related vain, you would do well to get rid of those solid repop hyatt replacements.
Slightly worn hyatt's would serve you better. Solids are hard on axle shafts.
Look for past discussions on the topic.
FundyTides
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post
by FundyTides » Thu Jul 10, 2025 2:31 pm
Great idea! There could be a subcategory of "Made in Canada" stampings. Here's one on a "slightly used" 26-27 runningboard. If you think this should be a seperate thread, that's ok too.
- Last Name: Farmer
Post
by 1925 Touring » Thu Jul 10, 2025 3:42 pm
The more the merrier
Anything T related with Ford on it.
It's amazing all the places it can be found.
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
Post
by Daisy Mae » Thu Jul 10, 2025 3:49 pm
FundyTides
- Last Name: Wilson
Post
by FundyTides » Thu Jul 10, 2025 6:24 pm
Here's my 27 motor with Ford Made in Canada on it and a 27 front hub showing Canada on the tag. I'll have took but I think Ford is also stamped on the hub
Post
by TRDxB2 » Fri Jul 11, 2025 2:48 pm
Door latch
Spring Clip & Bar, Ball cap, Spindle bushings, tie rod yoke (click on photo to zoom in)
Post
by Steve Jelf » Fri Jul 11, 2025 4:25 pm
CDooREDW
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Post
by CDooREDW » Fri Jul 11, 2025 9:26 pm
- Last Name: Farmer
Post
by 1925 Touring » Sat Jul 12, 2025 7:59 pm
MarkS
- Last Name: Sumner
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Model T Touring
Post
by MarkS » Mon Jul 14, 2025 1:46 pm
The OP didn’t specify that the “Ford” logo needed to be an original part, so here is my submission.
I added an electric stop light to my ‘15 touring, which meant i needed a stop light switch. The switch being near the trans inspection cover, I was worried that a tool might inadvertently short out on the exposed wire terminals when working down there, so I 3D printed a switch cover (black, of course) and decided it needed an “authentic” Ford logo.
Post
by Original Smith » Mon Jul 14, 2025 3:03 pm
In this hobby, I got the name Original Smith because of that. I was in my early 20's and was always looking for NOS parts with the Ford script. There was a junk yard in Gardena, that had bins of parts that came from an old store in Los Angeles called HENRY'S and LIZZIES. That is where I used to find a lot of those parts. I used to work there on weekends for free, and was rewarded with lots of those NOS parts for my time.
love2T's
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Post
by love2T's » Mon Jul 14, 2025 8:28 pm
Here's some from Keith Gumbinger.
Bryant
- First Name: Bryant
- Last Name: Shafer
Post
by Bryant » Mon Jul 14, 2025 9:34 pm
Hogshead. One of the bigger ones
Bryant
KeithG
- First Name: Keith
- Last Name: Gumbinger
Post
by KeithG » Mon Jul 14, 2025 10:22 pm
I haven't yet mastered posting pictures on the Forum so a friend posted these pictures for me just a few posts above.
The first one is a crankshaft with the script and part number shown and towards the bottom is a logo with a T over a W, which stands for Transue Williams, a common Ford parts supplier. You will note that this is a broken crankshaft and that it is a "diamond" shape between the rods. These crankshafts are notorious for breaking for two reasons: The diamond shape is weak and Transue Williams cranks are noted for poor quality. I will never use another one of them.
The second picture shows an original babbitt driveshaft bearing, the one that goes just behind the U Joint. Also shown in red primer is a round fellow wheel joining plate. You very rarely see these. I found this one at a swap meet and later noticed that I had them on both rear wheels on my '14 Touring. Quite rare. The last item is a castle nut from the rear spring perch on a TT truck. Why would Ford put script on an ordinary castle nut? Who knows, but I have found several others like this one.
Keith
- Last Name: Hatch
Post
by Dan Hatch » Fri Jul 18, 2025 10:37 am
Here is an nos tie rod bolt.
- Last Name: Farmer
Post
by 1925 Touring » Fri Jul 18, 2025 8:13 pm
Bryant
- Last Name: Shafer
Post
by Bryant » Tue Jul 22, 2025 6:00 pm
A different version of find the Ford.
Driving down a random back road I spotted it.
Do you see it?
Bryant
Post
by Allan » Thu Jul 24, 2025 8:36 pm
No.
Bryant
- Last Name: Shafer
Post
by Bryant » Fri Jul 25, 2025 7:55 pm
Post
by Allan » Fri Jul 25, 2025 10:54 pm
You don't often see this one.
- Last Name: Farmer
Post
by 1925 Touring » Tue Aug 05, 2025 1:22 pm
Find the ford
- Last Name: Farmer
Post
by 1925 Touring » Tue Aug 26, 2025 10:03 am
Find the ford
- Last Name: Farmer
Post
by 1925 Touring » Wed Sep 24, 2025 12:09 pm
Here's an interesting one I found on the aftermarket bumper on our 24 fordoor.
Harley_97
- First Name: Roger
- Last Name: Hallett
- * REQUIRED* Type and Year of Model Ts owned: 1924 Runabout, 1917 Runabout
Post
by Harley_97 » Wed Sep 24, 2025 4:03 pm
Starter brushes.
TFan
- First Name: Jim
- Last Name: Riedy
Post
by TFan » Wed Sep 24, 2025 4:43 pm
- Last Name: Farmer
Post
by 1925 Touring » Sat Oct 18, 2025 6:56 pm
Here's one you might not see that often
- Last Name: Farmer
Post
by 1925 Touring » Sat Oct 18, 2025 6:59 pm
Here's a few more from this weekend's work.
Ford theust washer with block letters instead of script.
Good thing I tore that rear end apart!
- Last Name: Farmer
Post
by 1925 Touring » Sat Oct 18, 2025 7:04 pm
And my personal favorite...
Pretty neat find I think
Post
by TRDxB2 » Thu Oct 23, 2025 12:53 am
![IMG_7827[1].jpg (105.6 KiB) Viewed 2800 times IMG_7827[1].jpg](./download/file.php?id=220218&t=1)
- Last Name: Farmer
Post
by 1925 Touring » Thu Oct 23, 2025 10:32 pm
- Last Name: Farmer
Post
by 1925 Touring » Fri Oct 24, 2025 10:07 pm
- Last Name: Farmer
Post
by 1925 Touring » Fri Oct 24, 2025 10:09 pm
- Last Name: Farmer
Post
by 1925 Touring » Fri Oct 24, 2025 10:13 pm
3 more from various spring leaves.
varmint
- First Name: Vernon
- Last Name: Worley
Post
by varmint » Sat Oct 25, 2025 10:30 am
Vern (Vieux Carre)
Colin Mavins
- First Name: Colin
- Last Name: Mavins
Post
by Colin Mavins » Sat Oct 25, 2025 11:11 am
I think it was typical for ford to mark everything when Dad and I built a ford GPW jeep every part had either ford or an F
Ron Patterson
- First Name: Ronald
- Last Name: Patterson
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout
Post
by Ron Patterson » Sat Oct 25, 2025 6:05 pm
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Post
by big2bird » Sat Oct 25, 2025 6:12 pm
TRDxB2 wrote: ↑Thu Oct 23, 2025 12:53 am
That's the rare one.
- Last Name: Farmer
Post
by 1925 Touring » Mon Feb 23, 2026 9:40 pm
- Last Name: Farmer
Post
by 1925 Touring » Mon Feb 23, 2026 9:41 pm
Are you a T fan?
rickd
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post
by rickd » Tue Feb 24, 2026 12:40 pm
Floor board starter switch.
