No sick cow?
Topic author - Posts: 2844
- First Name: Dallas
- Last Name: Landers
No sick cow?
Had horn apart. Cleaned it, bench tested it. Cleaned switch, tested wires, power to horn is good. Cleaned mounts on the head and water inletof rust and paint. If I run a ground wire to the body of the horn, I get a loud sick cow sound. Why is it not grounding through mounts?
Ruxstel24
- Last Name: Hanlon
Re: No sick cow?
Dallas, did you take the horn off the bracket and clean there also ?
Should ground through the bracket, so something is dirty between the path...
Mooooo !!
Mooooo !!
- Attachments
- IMG_4294.GIF (4.19 MiB) Viewed 1834 times
