TT C Cab windshield filler
abcarswell
First Name: Bruce
Last Name: Carswell
* REQUIRED* Type and Year of Model Ts owned: 1924 Model TT, 1934 Fordor
Post by abcarswell » Sat Feb 10, 2024 2:34 pm
Do any of my fellow TT C Cab owners have any information on the strip that fills the gap between the cab and the windshield. From what I can see on the parts book, it is likely called a visor part #TT12350. I assume it’s leather but would like to know dimensions, attachment details, etc. Pictures would be great.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: TT C Cab windshield filler
Post by Humblej » Sat Feb 10, 2024 3:26 pm
I have the Ford drawing, it is called Visor Assembly. The finished length is 36 7/8 x 3 1/4 inches. It is made of top material that is folded over a burlap core with binding on the ends. It is attaced to the front roof header on the inside and overlaps the front (outside) of the windshield frame.
abcarswell
First Name: Bruce
Last Name: Carswell
Post by abcarswell » Sat Feb 10, 2024 3:44 pm
Great Info!! Any chance that you could post the drawing? Is the attachment method shown ie type of fastners? My roof frame has been replaced over the years so there is no evidence left on my truck.
Last Name: House
Post by George House » Sat Feb 10, 2024 6:56 pm
Thats a good idea Jeff. I’d like to see the fastener method too for my C Cab. You’ve been real descriptive in dimensions. Thank you 🙏
Post by RajoRacer » Sat Feb 10, 2024 7:01 pm
Although the C-Cab lower w.s. is the same as the car, the top frame is identical to the car BUT is taller - a car frame fits right in also but leaves a heck of a gap at the top !
First Name: Jeff
Last Name: Humble
Post by Humblej » Sat Feb 10, 2024 7:46 pm
The Ford drawing is just for the finished visor, there is no fastener or installation info on the drawing. The visor assembly drawing shows the several pieces and the overall dimensions of the finished part, each piece has its own part number and drawing and conists of the following: 1) the top material outer layer; 2) the burlap core; 3) the edge binding.
abcarswell
First Name: Bruce
Last Name: Carswell
Post by abcarswell » Sat Feb 10, 2024 8:36 pm
Thanks for the info Jeff. It’s good timing as I have a top kit to put on and I’m pretty sure I’ll have enough to make this Visor.
abcarswell
First Name: Bruce
Last Name: Carswell
Post by abcarswell » Mon Mar 02, 2026 3:36 pm
I figured since I was posting today, I’d revive this old post and show how my Visor turned out. My sister is a pretty good seamstress so helped with sewing up some of my excess top material which I finally got around to installing today. I’m happy with the results.
