This is the last in this series, and is perhaps the most unique in overall design having a folded center support wall, vs. the traditional vertical. The six center holes are spade-shaped vs. oval or circular. The lugs are formed from semi circular designs rather than the previous curved step outs.
Essentially this has the same center set-screw/Woodruff key design as the previous T-725-B.2, as well as same set-screw to Thrust face distance. This style Clutch Drum tends to be paired with the later T-709-B wider Brake Drum, and was offered like all the others as repair parts. The Ford script is found on the backside (set-screw side).
Enjoy!
Jim Key
Accurate Models
Model T transmission Clutch drum series - Version 4
accuratemodelmaker
Topic author - Posts: 27
- First Name: Jim
- Last Name: Key
- * REQUIRED* Type and Year of Model Ts owned: 1915
