Water Neck Question
Scott C.
Last Name: Clements
Water Neck Question
Post by Scott C. » Sun Jul 14, 2019 6:11 pm
What is this water neck? It is leaking out of what appears to be rubber in the center of that brass nut.
First Name: Henry
Last Name: Lee
Re: Water Neck Question
Post by Henry K. Lee » Sun Jul 14, 2019 6:30 pm
An old circulator water pump accessory. Sometime long ago the drive was removed and plugged.
Hank
Scott C.
Last Name: Clements
Post by Scott C. » Sun Jul 14, 2019 6:40 pm
Should I just remove it and replace it with an original type water neck?
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Jul 14, 2019 7:04 pm
Would not hurt.
Hank
Post by DanTreace » Sun Jul 14, 2019 9:12 pm
Would be best removed, sometimes the old impeller mechanism may still be in place, or at least casting parts, these can block the thermo-syphon action of the Ford cooling system. Plain Ford part is better.
Scott C.
Last Name: Clements
Post by Scott C. » Sun Jul 14, 2019 10:37 pm
I was able do a "depression era fix". I cut a piece of inner tube patch and replaced the rubber button. It is sealed for now and was able to take the wife out for a sunset cruise. I will definitely replace it asap.
Post by DanTreace » Mon Jul 15, 2019 10:18 am
Scott
Here is what that 'Nims' brand water pusher looked like when new. A plug on the side of yours was the grease cup for the bushing, and a pulley ran a narrow secondary belt over the Ford belt to drive the impeller.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Mon Jul 15, 2019 11:09 am
Scott, I have several improved style water outlets, with nice pullies. Send me an email if you're interested.
Dave
