Identifying K R Wilson tools
ModelTWoods
Topic author - Posts: 1596
- First Name: Terry
- Last Name: Woods
Can anyone identify these K R Wilson tools? One is identified as a tool for setting end play on a Packard but does not specify year or engine. The other is identified as a Plug Gauge Set. Both are in their original K R Wilson wooden box.
Re: Identifying K R Wilson tools
Here are some sources of KR Wilson ToolsModelTWoods wrote: ↑Mon Mar 16, 2026 2:03 pmCan anyone identify these K R Wilson tools? One is identified as a tool for setting end play on a Packard but does not specify year or engine. The other is identified as a Plug Gauge Set. Will add other pictures after I resize them.
https://archive.org/details/kr-wilson-f ... 1/mode/2up
https://archive.org/details/kr-wilson-f ... nt-1931-32 ---
Packard website
https://packardinfo.com/xoops/html/index.php
Their tool/parts https://packardinfo.com/xoops/html/modu ... nLookup=Go
ModelTWoods
- First Name: Terry
- Last Name: Woods
Thanks, but the first two links, only pertain to Ford K R Wilson tools and the Packard link seems to only list non K R Wilson tools.TRDxB2 wrote: ↑Mon Mar 16, 2026 2:36 pmHere are some sources of KR Wilson ToolsModelTWoods wrote: ↑Mon Mar 16, 2026 2:03 pmCan anyone identify these K R Wilson tools? One is identified as a tool for setting end play on a Packard but does not specify year or engine. The other is identified as a Plug Gauge Set. Will add other pictures after I resize them.
1926krw.pdf
Packard website
Pep C Strebeck
- First Name: Joseph
- Last Name: M
Those are for the Packard Ultramatic Transmission, not an engine (prefix PU, Packard Ultramtic). The Ultramatic was introduced post-war ('48 or '49, I can't remember) and continued as the main automatic transmission for Packard until the end in 1956.ModelTWoods wrote: ↑Mon Mar 16, 2026 2:03 pmOne is identified as a tool for setting end play on a Packard but does not specify year or engine. The other is identified as a Plug Gauge Set. Both are in their original K R Wilson wooden box.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Thank You, Pep ! I knew someone would come through with the right answer. Since they are not for a Ford, they are FOR SALE, if any Forum reader is into Packards or knows someone who is.Pep C Strebeck wrote: ↑Mon Mar 16, 2026 10:31 pmThose are for the Packard Ultramatic Transmission, not an engine (prefix PU, Packard Ultramtic). The Ultramatic was introduced post-war ('48 or '49, I can't remember) and continued as the main automatic transmission for Packard until the end in 1956.ModelTWoods wrote: ↑Mon Mar 16, 2026 2:03 pmOne is identified as a tool for setting end play on a Packard but does not specify year or engine. The other is identified as a Plug Gauge Set. Both are in their original K R Wilson wooden box.
Terry you might post them in the Packard section on AACA.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Do you have to be a AACA member to post ? If so, is there anyone who would post an ad for me ?Mark Gregush wrote: ↑Tue Mar 17, 2026 12:57 pmTerry you might post them in the Packard section on AACA.
KimDobbins
- First Name: Kim
- Last Name: Dobbins
Pep C Strebeck
- Last Name: M
Ford six cylinder, early 1950's, I think.
Would have been used in conjunction with the KRW engine stand.
Pep C Strebeck
- Last Name: M
Yeah, it would have been helpful if I had not forgotten to include that salient point of information. Thank you for the back-up Mark.Mark Gregush wrote: ↑Tue Mar 17, 2026 7:00 pmWould have been used in conjunction with the KRW engine stand.
No you don't have to be a member but you can register on the site to use it.ModelTWoods wrote: ↑Tue Mar 17, 2026 1:42 pmDo you have to be a AACA member to post ? If so, is there anyone who would post an ad for me ?Mark Gregush wrote: ↑Tue Mar 17, 2026 12:57 pmTerry you might post them in the Packard section on AACA.
