27 fan pulley
Inthegarage
Last Name: Mosher
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pick up
27 fan pulley
Post by Inthegarage » Tue Aug 20, 2019 11:59 am
The fan pulley has about 3/16th in and out play on it. I just rebuilt it last winter with all new and fitted parts. I would like to remove it to find out what’s going on. Can I sneak the pulley by the radiator without removing the return neck? Or do I have to drain the antifreeze and remove everything?
Scott C.
Last Name: Clements
Re: 27 fan pulley
Post by Scott C. » Tue Aug 20, 2019 12:16 pm
On my 26, I was able to sneak it out of there.
Re: 27 fan pulley
Post by Mark Gregush » Tue Aug 20, 2019 12:31 pm
Before you take it off. Have you tried tightening the thru bolt first? Also look at your fan belt, is one edge more worn then the other indicating something is out of alignment. Could be that if the belt is too tight it is pulling the pulley in one direction wearing the bushing flange faster then it should. Flat belts do not need as much tension as a V belt, just enough to turn the fan (and water pump if so equipped). Another check before taking it off, are the pulleys in alignment both vertical and horizontal?
Inthegarage
Last Name: Mosher
Re: 27 fan pulley
Post by Inthegarage » Tue Aug 20, 2019 12:42 pm
I did check the tension of the belt and it’s not tight at all. If the thru bolt was loose wouldn’t the belt be out of adjustment?
jab35
Last Name: Bartsch
Re: 27 fan pulley
Post by jab35 » Tue Aug 20, 2019 1:00 pm
I haven't attempted that on my '26, but removing the eccentric with the fan assembly might require less 'space' than removing the bolt and fan from the eccentric. Taking the fan blade off the hub first should give more room too, but removing those 4 machine screws and the gasket on the blade presents it's own challenges I expect. The end play in a '26-'27 fan hub is minimal if the felt seal isn't totally worn away. Best, jb
Last Name: Humble
Board Member Since: 2006
Re: 27 fan pulley
Post by Humblej » Tue Aug 20, 2019 1:34 pm
John, did you install the felt seal and cup washer? If not that would account for about 3/16" play.
Inthegarage
Last Name: Mosher
Re: 27 fan pulley
Post by Inthegarage » Tue Aug 20, 2019 3:02 pm
Yes I did. But I think you should be able see it. I didn’t look with a flashlight yet, should you be able to see cup washer?
Later lm going to check the adjustment nut just to make sure it didn’t loosen up You gotta check the easy stuff first.
Re: 27 fan pulley
Post by RajoRacer » Tue Aug 20, 2019 4:57 pm
Yes, the cup washer should be visible - if not & you're seeing brass, that's the bushing !
Inthegarage
Last Name: Mosher
Re: 27 fan pulley
Post by Inthegarage » Tue Aug 20, 2019 5:41 pm
I checked the adjusting bolt and it’s tight. So tomorrow’s job it’s off with the fan :D
