Reverse snapping
Jfmarkham
Last Name: Markham
* REQUIRED* Type and Year of Model Ts owned: 1923 pie wagon
Reverse snapping
Post by Jfmarkham » Thu Mar 19, 2026 7:55 pm
My 1923 has started to occasionally make a snapping sound when its under a heavy load,it does it when backing up a incline or on soft ground. The noise is coming from transmission not rear end,any ideas where to start? Both forward gears work fine
