Hi,
Since I pulled the generator and vaporizer out, I thought I would use that opportunity and pull the valve cover off too and just take a look. Between the valves I found the number 23. Is that the production year? It’s a 1927 T, but it has the hole for the throttle linkage. The engine number says it’s a January 1927 engine.
Moritz
Number between valves
kernelpanic
Topic author - Posts: 3
- First Name: Moritz
- Last Name: Schnizer
- * REQUIRED* Type and Year of Model Ts owned: 1927 Model T Coupe
- Board Member Since: 2024
Re: Number between valves
Just a casting number.
