APCO Radius Rod Accessory
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Jul 24, 2019 10:24 am
My parts chassis came with this APCO radius rod thingamabob. I'm assuming it's a vintage one because the chassis was last a real car that was being used sometime back in the late 50's or early 60's.
It was really crusty and seized up but I managed to free up all the bits after soaking it for a few weeks in penetrating oil. After that, it cleaned up nicely. It appears to be missing the little cup that goes between the spring and the radius rod ball.
Also...a question: The spring seems to be really small compared to the inner diameter of the main body. Is that correct?
If anyone has a spare cup laying around, I'd love to "press" it into service (pun intended). ;)
1924 Touring
Last Name: House
Re: APCO Radius Rod Accessory
Post by George House » Wed Jul 24, 2019 11:50 am
Spring is correct. Little cup is available from most T vendors. Mailing will cost more than the cup. Wait until you have large order.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Jul 24, 2019 12:14 pm
Thanks George. I couldn’t find the little cup on Lang’s site....I’ll take another look.
1924 Touring
Post by Rich Eagle » Wed Jul 24, 2019 12:40 pm
Post by RajoRacer » Wed Jul 24, 2019 1:28 pm
The above is for the tie rod - here's the link for the radius rod cup - https://www.modeltford.com/item/2736APCC.aspx
Post by RajoRacer » Wed Jul 24, 2019 1:29 pm
My apologies - I referenced tie rod - it's drag link.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Jul 24, 2019 1:59 pm
Thanks...I had a few other things to order as well, so I just put in the order.
1924 Touring
