Disc brake install
paddy1998
Last Name: Delaney
* REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
Disc brake install
Post by paddy1998 » Sun Jul 21, 2019 9:04 am
Because I have a Ruckstell axle and no brakes other than the transmission brake, I decided to install the Sure Stop disc brake kit, both because I like driving my model T and I would also like to go on living.
It really is more or less a bolt on kit.
Minor annoyances:
1. To install the brake hose coming out of the master cylinder requires that you unbolt the starter switch assembly and shove it aside because there is a brake light pressure switch immediately aft of the master cylinder and you can't turn the hose fitting without hitting the starter contacts, which is unpleasant. :|
2. The master cylinder sits at about a 15 degree angle to Port for no reason that I can see.
Other than that, it's a breeze to install, as long as you don't drop washers and nuts in the transmission or have a machine shop drill out the lug holes of an aftermarket rear hub made in Hong Kong. ;)
paddy1998
Last Name: Delaney
Re: Disc brake install
Post by paddy1998 » Sun Jul 21, 2019 9:06 am
Hose connection
Post by Original Smith » Sun Jul 21, 2019 3:07 pm
So much for being original!
MWalker
Last Name: Walker
Post by MWalker » Mon Jul 22, 2019 10:31 am
"So much for being original!"
Said the guy whose Model T has a Scat crank and high-compression head.
