Help Removing wheel bearing race.
Modeltmike
Last Name: Sleep
* REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 22 center door, 23 touring, 21 touring and 26 Fordson.
Post by Modeltmike » Tue Jul 16, 2019 10:39 pm
I am changing wheels on one of my cars. I’m going to change the front wheel bearings. One of the outer races is worn thin and there is not enough “ledge” to get behind to knock it out. I am looking for ideas before I try my “untested” idea. Thanks!
Modeltmike
Last Name: Sleep
Re: Help Removing wheel bearing race.
Post by Modeltmike » Tue Jul 16, 2019 10:42 pm
I added a photo. Thanks
Walter Higgins
First Name: Walter
Last Name: Higgins
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Post by Walter Higgins » Tue Jul 16, 2019 10:43 pm
Carefully lay a MIG weld bead on the i.d. of the race, let it cool, and it will fall out when it shrinks.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Tue Jul 16, 2019 10:45 pm
Mike, if the race is junk, run a weld bead around it or heat it cherry red in two or three places and let it cool. Then turn the hub over and it will probably fall out on it's own. Dave
1925 mostly original coupe.
Doug Keppler
First Name: Douglas
Last Name: Keppler
Post by Doug Keppler » Wed Jul 17, 2019 6:54 pm
You could get on the edge of that with a sharp chisel, Ive never had a bearing race beat me. Come on Mike, you can do it!
1924 Touring car
There's No Substitute for Proper Lubrication
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Wed Jul 17, 2019 7:35 pm
Any kind of a weld on that bearing race will let it fall out!. That's the only way to get them out of a blind hole like in the top cover of a gear box. Done it many many times. Amazing!
1912 Torpedo Roadster
Modeltmike
Last Name: Sleep
Post by Modeltmike » Wed Jul 17, 2019 9:54 pm
Thanks for the ideas!. I like it. A bigger hammer and/ or more voltage. Tim the tool man Taylor would be proud. I will let you know how it goes. Thanks!
Walter Higgins
First Name: Walter
Last Name: Higgins
Post by Walter Higgins » Wed Jul 17, 2019 11:12 pm
What is your "untested idea"?
Modeltmike
Last Name: Sleep
Post by Modeltmike » Sat Jul 27, 2019 7:05 pm
Ground around on an old chisel. This allowed me to get over that little “hump” and get solid contact behind the outer bearing. Inner bearing was not an issue. Thanks
Post by DanTreace » Sat Jul 27, 2019 9:56 pm
Mike
Nice tool work.
Have done similar with a modified long masonry star drill.
Would like to find this tool, made for the job! Curved to bump out the inner or outer race.
IMG_8367 (500x409) (2).jpg (108.23 KiB) Viewed 5410 times
