Question IDing year on TT frame and other parts
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Sat Aug 03, 2019 1:30 am
I was doing a little research on TTs and had a bit of challenge finding things.
First I went the the MTFCA online Encyclopedia. Great resource, but I am not finding the TT info. (Also on the production numbers I don't see pickups listed: https://www.mtfca.com/encyclo/fdprod.htm I assume the truck is TT though.)
I did find the following thread helpful even though measurements are metric :shock: http://www.mtfca.com/discus/messages/33 ... 1366355695
There was this thread/conversation on the brackets:
http://www.mtfca.com/discus/messages/25 ... 1339216654
Is there anything else that would give simple pointers for the changes year-to-year on a TT?
Thanks,
Matt
Re: Question IDing year on TT frame and other parts
Post by Mark Gregush » Sat Aug 03, 2019 10:45 am
The Pickup started in the 1925 Model year so may be counted in the runabout/roadster listing. Truck would/should be TT only. What it boils down to, the more popular body styles (touring, coupe and runabouts) get the most research. 2 doors, 4 doors not so much. TT's even less. Good luck with your search.
