Old Photo on tour
Herb Iffrig
Topic author - Posts: 1716
- First Name: Herb
- Last Name: Iffrig
Old Photo on tour
This reminded me of the scenery at New London to New Brighton this weekend.
So many were in period clothing.
Re: Old Photo on tour
That is a 1914 Oregon license plate nicely mounted on the dashboard where it won't inhibit cooling. The rough looking background suggests an exciting excursion to me.
Look at that right front fender!
HornsRus
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
the fender is ok you are seeing the porch.charley
Looks to me like the right fender is bent down a bit. It's closer to the tire than the left one.
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Heinrich sends along the following information:
This photo was taken where the road ends in Silver Plume. Hilda Gruenwalder had
traveled to the Chugwater district to visit her father there at the mine cabin/office
in the summer of 1916, before the Nutmeg Incident. The car made the trip to and
from Oregon on a railroad flat car, and was just used to tour around the area after
being unloaded at the Calhoun County Co-op's ramp in Saddle String. They loaded
the car back up and pressed on to Pispacattiquattimawken, where George's Uncle
ran the local Sanitary Cafeteria. They returned to Hoskins in October, where George
resumed his position as dispatcher/telegrapher for the Valley & Siletz.
Walter Higgins
- First Name: Walter
- Last Name: Higgins
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
The front fenders are mismatched. The bills are different.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Those are not mis-matched fenders.
You are confusing the porch and a shadow under the porch with the fender. It's an optical illusion.
Look harder and you will see the passenger fender is the same as the driver fender.
Walter Higgins
Yep, you're right. The line there is a bit fuzzy but I can see what you're saying. Tricky.
